Basement color
post #1 of 3
Now that my theater room is complete. I want to paint the other side of my basement which is basically a short hallway leading to the laundry room, bathroom and closets. Should I paint that side the same color I have throughout my house which is like a light goldish color or try to find something that will compliment the theater room? Maybe like a light blue or something. The issue here is that I don't have a door to go into my room. Its an open walkway. So whatever I decide, it should compliment that room I am guessing. To keep it simple, I may just use the same color I have throughout the main part of the house which is called Camel from Behr.
Post #10 in my build thread you can see the hallway I am referring to with the screen leaning up against the closets and Post #24 in the same thread you can see the color I have throughout my house leading to the basement.
Just looking for some suggestions on keeping the same color or choosing a totally different color for that hallway.
post #2 of 3
I would have the paint match the rest of the house. That way, the theater remains it's own special room.
CJ
post #3 of 3
Cool...thats what I am probably gonna do just to keep it simple.
