Originally Posted by freshane
I recently got a Logitech Harmony 1 remote.. I really like this remote, works great and gets rid of all my other remotes. I was wondering if there is a way to press one button to get the temperature reading on the display. Rather than pressing display, standby, then tone. Anyone know a way I could add this to the remote?? Thanks
Do you have to hold down all three buttons at once or do you press them in sequence? If you have to hold them all down, I have no idea how to do that with a Harmony. I don't think it's possible.
But if it's a sequence of buttons, you can do that with a macro. Pick an activity, click on 'customize buttons'. At the bottom left corner there's a button that says 'Add Sequence'. Click that, then you can specify the key presses that you want to happen. Then it'll save the sequence as a new command. Then just assign that command to button; as a soft-button on the screen or a hardwired one, your choice.
