AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Onkyo TX-SR876 Owners Thread
The "Official" Onkyo TX-SR876 Owners Thread - Page 91
post #2701 of 4979
Originally Posted by Kevlar79 View Post
Thanks for the reply, I didn't realize the image failed to attach. It should be in this post. I'm positive that my speaker wires are all connected properly. I did go through and reconnect all of them just to make sure. I'm also using banana plugs, so stray wires should not be an issue. The test tones are equally loud from all speakers. Any other ideas?
Try to find if there is a specific speaker that is causing problem:
a) connect ONLY the front left and right and do the setup.
b) add the center and do the setup.
c) add the surround left and right and do the setup
d) add the surround back left and do the setup
e) add also the surround back right and do the setup
f) add the subwoofer and do the setup
post #2702 of 4979
Thanks for the help, I'll give that a try when I get home this afternoon. Also, I just noticed that in the picture I attached previously, my center channel does not show up. Perhaps it is my center speaker that is the problem.
post #2703 of 4979
Yes, could be. Make sure it "sounds" correctly when stepping through the level settings in the menu.
And try swapping the front left speaker cable with the center's cable
to see if the problem follows the speaker or the wire...
post #2704 of 4979
YEP. I was going to post that your center channel is missing but my internet went down until now. You may wish to check that FIRST!
Best,
Chris
post #2705 of 4979
So it seems that my DefTech CLR3000 center channel is causing the speaker detect error. I had an older speaker that I put in its place and the calibration completes without issue. In addition, I took the CLR3000 over to a friend's house who also has the Onkyo 876. Guess what? He gets the same speaker detect error when we connect the CLR3000 to his 876 and run through the calibration. I'll be calling DefTech today to see how best to get this resolved.
post #2706 of 4979
Well, good to have the problem isolated at least. Good luck!
post #2707 of 4979
Is sound, other than the test tones, now being sent to the speakers, for example, sound from a DVD/Blu-Ray?
Thanks, Bill
post #2708 of 4979
For those thinking about upgrading their DSP & main firmwares...
Edit-> Upgrading from 1.01 to 1.04 main firmware does not wipe all the settings, but updating the DSP firmware does wipe all the settings (apart from the Audeyssey calibration info). (Thanks Bill)
So write those things down before you upgrade your DSP formware.
post #2709 of 4979
Originally Posted by WSquared View Post
For those thinking about upgrading their main firmware...
When I upgraded from 1.01 to 1.04, all my settings (apart from the Audeyssey calibration) got wiped. Annoying since I needed to run the Audeyssey calibration again anyway after getting a load of new cabling.
It was surprising how many details in the config I had forgotten how I had previously set them. At least this time, I had Rickardl's notes in addition to the manual. I still need to work out all the the listening mode preferences that I had previously chosen.
So write those things down before you upgrade.
Did you do the DSP version update as well? When I upgraded the FW from 1.01 to 1.04 with my 886 I did not lose my settings. When I updated the DSP version on my 805 that is when I lost all my settings. I believe when upgrading the FW you should not lose your settings, only with the DSP upgrade.
Bill
post #2710 of 4979
I did not lose any settings either. (1.01>1.04)
post #2711 of 4979
OK so I've done my research and have downloaded the firmware files and am almost ready to go. Just a few questions. I have an Onkyo 876 (US Version).
Firmware versions show that DSPs are all okay, but firmware main is 1.01 on my unit. I'm interested in upgrading to 1.04 to get rid of the gamma bug that affects me, and to get additional discrete remote command functionality.
The 1.04 firmware I downloaded looks straightforward enough, but I see the files for the very latest (1.05) are called DH99, supposedly for the Integra 9.9 series??? Is Integra firmware okay for us in the US? Supposedly 1.05 is the same as 1.04 anyway, so why should I even bother? Perhaps I should just update to 1.04 and leave it at that?
Finally, I see that HDMI has an update. I've never encountered the opportunity to play music with the TV off so perhaps I don't know what I'm missing. Should HDMI be done before the main update or after?
Thanks in advance folks!
post #2712 of 4979
HDMI update? What? where? I don't have that...
I had 1.01 on mine and went to 1.05 and have had no issues at all.
Do I know the difference between 1.04 and 1.05? Yep, 1.05 is .01 better than 1.04, other than that beats the hell out of me? Where is this HDMI update you see?
Best,
Chris
post #2713 of 4979
Originally Posted by radamo View Post
Since I have only had mine working for a week I am still getting familiar with it. I have been running it now with an HD DVR source for about an hour. It is set at -19db and is up to 52C so far. I guess that is not terrible. I will give it another hour and see where it ends up.
Okay... update after 2 hours and now at 57C. Seems to still be climbing slowly. My room temp is 74F and I have a ceiling fan circulating the flow. My den is now warming slowly due to the heat this thing puts out. I will love it in the winter.
RA
Update 7/23: Just received a fan kit from Coolerguys.com (http://www.coolerguys.com/comcool.html). The fan is silent and after 4 hours my 876 has only gone up to 45C. For me this is the perfect solution. Since my glass open rack only has about 2" clearance above my 876 I thought it best to add some cooling. This is exactly what I was looking for.
RA
post #2714 of 4979
Guys, thanks for all your help. Your troubleshooting steps helped me isolate the issue to my center channel. After speaking to DefTech the problem is solved.
Thanks to Chris Volk at DefTech and Adam in DefTech tech support! A speaker wire connected internally to the binding post came disconnected during shipment. As a result, the tweeter in the center was not playing at all. After re-connecting the internal wire the center is working properly and I was able to successfully complete the Audyssey calibration with all speakers connected.
post #2715 of 4979
Best,
Chris
Here's the HDMI update 1.02: http://www.avsforum.com/avs-vb/showt...=#post16803821
Apparently it fixes an inability to play music while the connected TV is off, for instance if you use your Blu-ray player as a CD player, and then turn off your TV, no more sound is output?
post #2716 of 4979
That HDMI update is for the xx5 series... does it also apply to the xx6?
post #2717 of 4979
That is something I have been wondering myself. Anybody have any further information? I'm going to test the music thing with the TV off. If it's not an issue for me, I won't proceed any further.
post #2718 of 4979
If I turn my display off with any source... the receiver mutes for a second then comes right back on. If the display is off to start with, all works just fine right from the beginning.
post #2719 of 4979
Confirmed. Thanks for bringing this to my attention. I might have really rogered myself up!
post #2720 of 4979
Well... with as little help as we get from Onkyo, we gotta cover each other's backs on this stuff!
post #2721 of 4979
I just went to Amazon, and my cart told me that the price went up from something like $740 to $1694 for this receiver. I never noticed that it had dropped in price so much, or I would have probably bought it. I've been waiting to see the specs of the newer model.
post #2722 of 4979
When are the newer ones coming out. The press release for the 876 was 9/24/08 so I wonder if in Sept the new ones will be announced.
post #2723 of 4979
Hey someone from Naperville here! (I work there at Nequa Valley)
Perry, that price at amazon was a boo boo. It was only at that price for a couple of hours. There is a whole thread on slick deals about it. If you don't know it Amazon has the screwiest pricing in the whole world. Stuff can change in MINUTES, (and often does) Next time you see an insane price like that, you should buy first then you always have the option to return it. By the time I had posted it in the "Great Found Deals" Section of the forum, it had gone up to $1100, then just became out of stock. MY only wish was that it would have been the 906(but I am greedy).
Best,
Chris
post #2724 of 4979
The Amazon price wasn't a boo boo. Amazon just has crazy deals that last for minutes or a few hours sometimes, and then the deals are gone, like you mentioned. Just can't take too long to decide, or the deals disappear.
post #2725 of 4979
Bill
Yes, I did update DSP#1 just before the main firmware. I guess that'll be what did it then. I am surprised that the main firmware doesn't wipe the settings, but the DSP does. Seems backwards...
post #2726 of 4979
Normally I would agree with you, but this time, no. It was most definitely a screw up with Amazon. The ONLY people that got these were Prime members and the very very few that opted for one or two day shipping. They flat out CANCELLED all of the other orders at that silly price. If it was a sale, they would have just kept those orders and filled them as more came in. A ton of people were upset because they were able to order and be billed at that crazy price and then...BAM...they pulled the rug out from under them. The only reason they did not cancel ours is because of the fast shipping methods used and that Amazon processes and ships stuff pretty darn fast!
Best,
Chris
post #2727 of 4979
I'm running a laptop with Windows XP Professional, SP3 (32-bit). It has a serial port and I am running a serial cable directly to the Onkyo 876. I'm trying to update to Main firmware 1.04, but when I launch the update.exe file, and then click Main Update, nothing happens.
I'm using the update.exe in the App_Updater_876 directory, and have installed the VB6 files. I am using COM1, and even tried a different laptop, but no joy. Could be the serial cable I guess, I'll have to see about getting a different one to try.
Is there anything else I can try? sounds like Larry might have had a similar problem, at least initially. How did you get around it?
post #2728 of 4979
I just updated my 906 and there are some quirks in the update software, but the first thing you might do is ensure that the PC serial port is on com 1.
I elected to use a USB to serial port cable from monoprice.com. I did that rather than get a serial cable just because only the oldest of my PCs has a serial port. The DB-9 male plug did not seem to insert fully in the 906 DB-9 jack. The internally threaded hold down nuts (like you would expect to find on a female jack) seemed to interfere. It was easy to remove them (permanently) with pliers. I should have been more alert.
The included mini-disk of drivers was not interesting to the elderly XP box I was using, but the downloaded drivers from Prolific Software worked fine.
The converter installed on com 3. The firmware Updater seemed to allow for a choice of Com 1, 2 or 3, but nothing happened when com 3 was selected.
I used Windows Device Manager to disable the serial port on com 1 and reassigned the usb converter from com 3 to com 1. When I restarted Update data appeared just as shown in the instructions. I elected to check the log box which also made an xxxxx/29500 progress counter visible. The port speed was the default 9600.
Installation was slow but certain taking perhaps 30 minutes + to complete. All settings seemed the same.
post #2729 of 4979
Chris, what are you doing with the three TX-SR876s you just bought?
post #2730 of 4979
The Main firmware seems to be the same for Onkyo TX-SR876, TX-SA876, TX-NR906,TX-NA906,TX-SA806X,TX-NA906X,PR-SC886 and Integra DTR-8.9, DTX-8.9, DTR-9.9, DTX-9.9, DHC-9.9.
