Originally Posted by henningdalgaard
Could it be the fact that the monitor only has DVI input and not HDMI? I use a converter. The pc is sending 720x1280 which is the native display of my main display, sanyo Z4. I know that the acer could display that resolution when it was connected directly to my pc.
Not likely... DVI video is electrically the same as HDMI video (at least in the formats/resolutions we are talking about here)... just the connectors are different (a passive mechanical adaptor is all that is required). Besides the differing connectors, HDMI also adds audio and control support.
Are you sure that the PC is remaining at 1280x720 when you connect it to the Acer monitor? Unless you prevent it by forcing settings, it should be automatically sending the Acer 1920x1200 just by the normal handshake process (display adaptor reading the displays EDID and sending the display's "optimal" resolution automatically). If you pop up the info display on the Acer, does it actually say 1280x720 is the currently displayed resolution?
