Originally Posted by jon0966
Hi All -
Have had an SR876 since Dec 08. I have my Directv and WDTV box both connected to the SR876 via HDMI, and then HDMI to my TV. The SR876 sits on an open glass shelf, so heat should not been an issue.
A few weeks ago, the Onkyo reported no signal from the Directv and WDTV box. I disconnected the SR876 for a few weeks as I left town on business.
Upon returning, I plugged the SR876 back in and it worked for a bout a week until today when I moved the SR876 but due to a loose power cord, the SR876 turned off.
Now I either receive the "No Signal" or if the SR876 does detect a signal the output to the TV is mostly of a green color (please see picture attached).
The only Onkyo authorized repair center that I can find in Houston is 50 miles away and the reviews of them are bad.
What are some thoughts on what the problem could be and would anyone guess as to what I should expect to pay in repair?
Is there any troubleshooting I could do at the house before sending in for repair?
J
Hi All -
J
This is one of the symptoms of the caps on the HDMI board going bad... Mine did exactly this. It will get worse over time until it will not work at all... It will cost you ~$400 to repair or ~$1000 to replace. You could try to replace the bad caps, see post 402 in this link...
