Glad it worked out because I was going to say...the 876 can blow some doors and windows when set up properly.
As others have said, I really encourage you to run Audyssey and follow the instructions on the first page of The Official Audyssey forum here on AVS to the letter--it made a big difference in my room.
Finally, I highly recommend you getting a fan for at least the top left rear corner of the unit as the 876 runs hot which has caused many users, including myself, to have to replace the HDMI board. I'm using a Coolerguys.com av component fan and it works great.
Enjoy!
You can use this one as I guess there are only minor differences to the 875 with regards to your problem.
