AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Onkyo TX-SR876 Owners Thread
The "Official" Onkyo TX-SR876 Owners Thread - Page 169
post #5041 of 5049
also what baud rate should i be using?
post #5042 of 5049
Hello,
My 876 is not sending audio to the left front channel. I have swapped out speakers and cables, and done a factory reset... still no sound on left channel.
Any ideas on what would cause this issue?
Sorry if this has been covered before, but a search didn't yield any relevant results.
Thanks for the assistance.
post #5043 of 5049
Here's a Youtube video on repairing a Onkyo 606 HDMI board. Excellent video on how to repair the board and the techniques to use. Repairs to a 876 will be somewhat different, especially the number and location of the capacitors compared to a 606 HDMI board. But, shows how easy it is to make the repair.
Edited by eaayoung - 3/9/14 at 7:56am
post #5044 of 5049
Originally Posted by krahulec View Post
Were you able to fix your problem? Our power went out last night, and when power came back on, the sound no longer worked. I get the same uninformative DSP1st ?????? ?????? in Debug mode.
Krahulec, I have the same issue after a power outage. My 876 has no audio and it displays DSP1st ?????? ??????. Did you managed reinstall the DSP firmware? Have you been able to find a solution?
post #5045 of 5049
I purchased my 876 second hand, and noticed that the HDMI switching is much slower than on my 607 -- can some of those who bought it new comment on whether this is normal or is it due to capacitor deterioration on the HDMI board? I replaced all the 100uf caps but of course the others could be bad as well.
post #5046 of 5049
I can say that my 876 has never been fast, an HDMI handshake takes up to 8 seconds.
post #5047 of 5049
Mine is about the same.
post #5048 of 5049
Thanks guys, no need for me to fiddle with it then! A minor annoyance but one that I can live with.
post #5049 of 5049
Dear all,
I have an Onkyo 876. All of a sudden lost all connectivity to HDMI ports while I still have OSD visualized on the TV .
There are no "clicks" from the relay, while I switch between the different ports and "No signal" is displayed.
The 100mf capacitors were exchanged as described. Unfortunately this brought no results.
What may I try next? There is no official Onkyo support in my area.
Thanks for your help in advance.
Edited by Alexandro77 - 4/7/14 at 3:42pm
