This is the first "big boy" system I will be purchasing (big boy for me that is). It will be paired with 1080p Plasma and a PS3. It is easier for me to compare receivers on the market from a features and benefits standpoint because it seems quantitative (2hdmi vs. 4, 1080 pass-through vs. up convert). However, assessing the overall value in the speakers is very qualitative and I do not have the expertise to go this course alone. Please help me with your knowledge and guidance if you can.
I am currently debating between purchasing the Onkyo HT-S7100 HTIB system or purchasing the SR606 receiver separately and pairing it with a speaker system or putting one together (both systems use the SR606). I was looking to buy a beginner system that I could still grow with and narrowed my search down to the SR606 system with 4 HDMI inputs, 1080 up convert, and multiple system set up options (5.1, 7.1....). I will be moving into an apt at the end of this month and will initially only be using the 5.1 set up. My dilemma is below:
1. HT-7100 is on the market for $749 OTD (VANNS)
System includes 7 satellites, two stands, ipod V/An input, 230 power 10" sub
2. SR606 is on the market for $379 OTD (Tiger Direct)
Receiver only
Option 2 leaves me with $370 to spend on a speaker system. My max budget would be $420 for speakers and would keep me under $800 total.
Do you have any suggestions for a speaker system that I could put together for less than $420 OTD that would be a better value than the HT-7100 HTIB? I would only need a 5.1 system with a sub to start with, and then I could add on down the road.
Your time and help is greatly appreciated.
Receiver only
