AVS › AVS Forum › Other Areas of Interest › Camcorders › Security Cam
Security Cam
post #1 of 2
Are there any Security cams that I could install in my store that allow me to get a live feed on my PDA? Any guidance in the right direction would be great.
post #2 of 2
You can buy one of those "netcam", a wired one if there is a router / internet connection nearby, or a wireless one for flexibility in netcam location. Or if you have a PC in your store, you can use any web cam to do the job (though your PC needs to be on at all times).
For wireless netcam, I highly recommend Panasonic BL-C131A. Apart from decent picture quality, swivel and tilt, the best is Panasonic's completely free Viewnetcam service, which makes it very easy for novice to setup remote viewing, like what you want to do with your PDA.
  Back to Forum: Camcorders
