I'm curious about any issues regarding playing PAL disks on a primarily NTSC system. I recently took a chance on PAL versions of African Queen and Crimson Pirate since they are unavailble in region 1. My Denon 2900 DVD player states it can output PAL (but is not region free) and my Sharp 10K projector can output PAL but for some reason only through the S-Video cable.
As an experiment I bought the region 2 disks and burned them to DVD-R's to remove the region protection and then played them through the Denon 2900 to the Sharp 10K projector through the S-Video. The quality was not as good as I expected. Crimson Pirate was definitely worse then a now OOP NTSC version I once saw was. The main issue (i'm not sure the official term) was a shimmering effect at times where it plainly looked like lines of resolution were removed and the image spliced back together giving a stepped look. I don't know if this is considered "tearing" that I have heard can happen.
I expected with the increased resolution (576) being upconverted to 720 it would be better then 480 upconverted to 720. But it was almost like the 576 was first downconverted to 480 before being upconverted to 720.
My thoughts were that maybe the Denon is not good at PAL or maybe going through S-Video was the problem. Recently, I rented the first disk of "Wanted: Dead or Alive" season 1. I read that these were converted to NTSC from a PAL copy. While not bad quality I did see very similar effects that were distracting at times. Especially, along the brim of a hat or when looking at a person's eyes. This disks was reported to suffer from PAL speed up which didn't adversely affect my expereince.
If I decide to continue with PAL I will probably get something like the Oppo 983 or hold out for the Oppo 83 BR player, but first I want to make sure about the quality I can expect.
For those who watch PAL disks in region 1:
- Is this common behavior you must learn to accept or is this about my dvd player and projector not being able to handle PAL very well?
- Would an Oppo 983 converting to an NTSC signal then scaled and sent to my projector through a digital connect clean this up?
- If it is my hardware, was the issues I saw with "Wanted: Dead or Alive" just the result of an subpar conversion?
Sorry for the long explanation but I would value hearing from anyone experienced about these issues.
