Hello all, I'm new here and a bit overwhelmed by all the information. But this looks like a great place to get help. We are just about to undertake our basement remodel, and I'm trying to figure out what we need to buy, and what sorts of outlets/connections we need to put in.
We have now: XBox360, Wii, DirecTiVo receiver (which I imagine we will need to upgrade to a newer high def one).
We are going to get a 46-52" flat panel tv. (We'll figure out exactly which one once we're ready to put one in.)
Am looking at 5.1 channel with subwoofers.
Imagine we will get a blu-ray disc player later on. Right now we just play DVDs on the XBox.
Writing this out, it doesn't seem too bad. I guess the A/V receiver is the thing I have no clue on.
Questions...
1) So I guess I need an a/v receiver for the 5.1 Channel sound + subwoofer, with RCA inputs for the Wii, HDMI input for the XBox360, HDMI? input for blu-ray dvd player. Anything else I should keep in mind? Any recommendations?
2) Having the receiver means I only need an HDMI cable and a power cable to the tv, right?
3) Speakers - I think in our setup that two in-wall speakers behind the couch, and then two shelf speakers for left/right in front. I'm not sure where we'd put the center speaker unless they come in a narrow size so that it will fit under the tv. How small do these things get? Also subwoofer - can it fit under the couch?
4) Circuits - Going by my list of components, will one dedicated circuit suffice?
I'm sure I'll come up with more questions later.
I will keep you posted on our progress.
Questions...
But I will go ask about receivers and speakers in their respective forums. There's still a few general questions in there though.
Playing Rock Band on that sucker is no fun at all.
If there's a section for "not really a home theater system, but better than a sucky 19" tv", then maybe someone could move my post over there.
