Sure Thing:
Basically all projectors that feature an elaborate picture processing chip run have an input lag of around 1 frame (30ms). The cheaper processors with less picture enhancing capabilities usually are hardly ever over 16ms delay: Epson TW3800 Infocus IN82.
From what I experienced while testing around 8-10 projectors all that matters is the included picture processor. I discussed each result with my Home Cinema Dealer and he told me which chip was included in which projector. In the end he was able to "predict" the lag of a projector I was about to test by the processor included.
Basically that leaves us gamers with 3 options:
1.) Buy an older/cheaper projector with a decent picture quality (i.E Epson TW3800 or Infocus IN 82) and be happy with the compromise between picture quality in movies and low input lag. Good picture processors simply create input lag.
2.) Buy 2 Projectors 1 for Gaming, 1 for Movies
3.) Buy an up to date modell with an elaborate pixel processing chip and connect your computer via a short high quality VGA Cable. I am unsure how "bad" the picture itself will be and if that really "eliminates" all input lag since I did not test that yet. Could anyone give that a shot ? Ideally on a D-Ila JVC HD350 or the Sanyo Z3000 since I really liked the movie picture and Desktop sharpness of those projectors.
Pictures will follow on Sunday - promised =)
regards,
frex
regards,
frex
No wonder links are so hard! I broke the bank on this projector with plans to not upgrade for many (5+) years. I really need it to work better for SFIV!
