Here, pull my fing.... uh, check this video I uploaded:
http://media.putfile.com/Kappalite_weird_noise
This is my Eminence Kappalite 15" sub on an EP2500 amplifier. I had it hooked up in stereo. So the 8ohm kappalite was drawing about 450 watts.
I have been bothered by an odd sound. At first I thought there was something wrong with the speaker. But now, I'm not so sure. It may have something to do with my setup?
Onkyo TX-SR705 a/v receiver feeds directly into a Behringer EP2500 amp. I had the same problem with a Behringer BFD1124 in the chain also.
At the following db levels/frequency is when the weird sound starts happening. This is with 450 watts at full gain.
20hz @ ~72db
25hz @ 89.3db
30hz @ 97.5db
35hz @ 101.6db
3/4 gain = 99.8
1/2 gain = 95.7/106
If I move that down to 3/4 gain, then I get the weird noise at 99.8db with 35hz insteado f 101.6 earlier. If I move it down to 1/2 gain, then the noise starts at 95.7.
So then I went and bridge power to the kappalite. Now it's getting 1300 watts.
Now at 35hz, it doesn't start making the noise at 1/2 gain until 106db.
Does anyone know what this noise is? It doesn't appear to be bottoming out because the speaker cone is hardly moving.
20hz @ ~72db
25hz @ 89.3db
30hz @ 97.5db
35hz @ 101.6db
3/4 gain = 99.8
1/2 gain = 95.7/106
I have had to deal with this problem on all my receivers and I have owned all brands.
