Originally Posted by
Trackman
It would sure be nice if the DD+ bitstreaming dropout/skipping issue is fixed.
Trackman, can you elaborate a bit more on this problem? I have something similar. I put on Transformers which is Dolby Digital Plus ONLY and it skips every 30 or 40 seconds which is very annoying.
It does the same thing with Aeon Flux but this time because that disc had DTS I tried that and NO SKIPPING.
However, with every other disc I've tried including Bourne Ultimatum, 300, Batman Begins, there is NO problems with Dolby Digital Plus or any of the lossless codecs like True HD either.
I then tried with HD DVDs that have ONLY Dolby Digital Plus on them like Transformers such as Robin Hood and had NO problems.
So far, I've only had skips with Dolby Digital Plus on Transformers on Aeon Flux so what is going on and where is the problem? My XA2, the discs, or both?
It is VERY annoying because Transformers gives me no choice other than to either play it on my Xbox 360 HD player or buy one on Blu Ray.
Will turning the option to PCM from Bitstreaming solve this issue and is this an acceptable work around for this title?
And does anyone know if 4.0 fixes this??
Thanks for all input.
Dennis
