Originally Posted by
skizzoid
Not sure if this is a problem per se, but when I updated to version 4.0, I lost PAL video output in my XA2. I have a Panny 50PZ800U, and with version 2.7, PAL discs play fine, but only in 1080p/24 mode. And after I upgraded to 4.0, Region 2 PAL discs would still play, but there wouldn't be any video signal (and I played around with the video settings on the XA2 and Panny for a while), just sound. Maybe someone else had different experiences with PAL output and the 4.0 firmware, but it was enough for me to drop back down to version 2.7, which has been working perfectly fine.
How did you go back to version 2.7?
I have the A20 and i found that with SD DVDs I cannot use 1080p/24Fps output without a lot of jaggies AND very strange unnatural motion effects. When I change the output to 60Fps these issues go away, but I do not want to have to go into the setup to change it back & forth. I did not have this problem with version 2.7 so I need a way to go back.
Has anyone made a version 2.7 ISO with the binary correction to overwrite version 4.0?
Thanks in advance for any help with this.
Nevermind:
I figured out how to change the header info in hex and created a modified ISO of image 2.7 that can overwrite version 4.0. If anyone needs it also, just let me know.
