AVS › AVS Forum › A/V Control & Automation › Remote Control Area › how do you find the IR Sensor on your equipment??
post #1 of 9
i have a cable box, a denon blu-ray player, reciever, I cant figure out where the IR sensor is where I can put the mouse from Xantech. How do you find it?? I have no idea how to look for it if it isnt explicitly marked... please help?
I really cant find it on the Comcast HDMI cable box
post #2 of 9
I shine a flashlight through the front panel, hold it right on the surface and it should be easy to see, also sometimes the manual has a good picture of where it is located.
post #3 of 9
i didnt get a manual with my comcast HD cable box, its a hdmi silver box... i guess i'll try to shine one tomorrow. what exactly am i looking for?
post #4 of 9
A camcorder with nightvision mode makes it extremely easy to see through the panel. But if you don't have one, a flashlight works too.
The IR sensor will look like an LED, except it'll probably look black. They typically have a metal shroud around them.
post #5 of 9
If it's a DCTxxxx box, it's on the far left side of the oval display. If it's a newer DHCxxxx box, it's above the ch+ button. I really wish they would have put an IR input on the back pannel.
post #6 of 9
yeah i have a camcorder, i tried the night vision thing but i could only see the emitters on the remotes, never on the receiving devices. Anyway, I took each of the boxes up to the sun and then I saw the IR receivers, so I made my connections. so far so good, thanks for the help
they really should mark off the IR sensor on every electronic manual. thats just rediculous to have to hunt for it.
post #7 of 9
So... was I right?
post #8 of 9
If all else fails, have someone stand in front of the gear and take a 3"X5" card and move it in front of each piece of gear until the remote stops working. Then fold the card in half - now a 3"X2½" card and narrow it further. Finally your thumb or similar will nail it down. (Would that be a thumb nail? )
post #9 of 9
Originally Posted by eddielives View Post
So... was I right?
yea you were.
  Back to Forum: Remote Control Area
