Originally Posted by geocab
Quick question on the Transporters, in the US release the list says, "theatrical", but both the Japanese and French releases do not. Does this mean that both the French and Japanese versions of both movies are uncut?
I want to buy the uncut versions of these movies and can't decide if I should buy the French or Japanese versions, this is why I ask.
http://www.dvdcompare.net/comparison....php?fid=10265
http://www.dvdcompare.net/comparison....php?fid=10220
Looks like the French and Japanese are nearly identical, except audio and French extras may be PAL. Both Uncut. I can say the Japanese releases looks incredible. They had a slightly more natural color, not quite as yellow/orange saturated as the US releases. It was still slightly over saturated though. The Japanese are high bitrate AVC, often in the upper 30-40Mbps. I think the Japanese releases are reference, both PQ and AQ.
I have no idea how the French releases compare PQ wise to either.
Edit: someone had noted the French releases were low bitrate AVC and exactly 24fps and not the usual 23.97fps. Also they do have PAL extras.
