Marantz Vp8600
post #1 of 4
Is the Vp-8600's 800 Ansi lumens bright enough for my room? I have a 1.3 gain screen, with a little ambient light, just enough to read with? thanks for the help.
post #2 of 4
Before anybody can answer that, you'll need to provide your screen size.
post #3 of 4
92"
post #4 of 4
In economy mode you should have around 20 FL. on your screen. When the lamp is at half power (+ 2,000 hours) then you might need to go to normal lamp mode.
