I have been using my F100 DtvPal's since the first of July.
Yes I have multiple boxes.
They are connected to an antenna on top of the 2nd story of my home.
I have been experiencing the same problems as mentioned in this forum.
The heat issue is more of a problem with one particular box.
I have been receiving all the stations in the Dallas area.
On Friday afternoon Sept. 19 all signals on all boxes(including my Insignia box) went weak for about an hour.
When the signals came back up to the levels I was used to seeing, my
DtvPals would no longer lock onto KERA digital 14.1.
The signal meter fluctuates between 0 and 80.
I have checked all of my antenna connections, grounding and cabling.
I even tried a different(same make and model) antenna on the the roof.
I dropped a coax directly from the antenna to the DtvPal.
I sent an e-mail to KERA asking if they made any changes but have not received a response.
My Insignia box still locks on to the KERA signal.
Has anyone else experienced a similar situation?
Any suggestions?
Any suggestions?
Posts elsewhere on AVSforum go unanswered. I would really like to know if the sensonic/lasonic crowd with a silicon tuner can still tune in WETA, because I sure as h&&& can't... Except with my DTVpal! Go figure.
