Well, I think that the time has finally come; I've had it with the display switching problem on my HTPC!
I am looking at the DVI Detective Plus, and I've heard that it will do what I want, but I'm a little confused as to the correct cable flow when using an ATI 4850 with HDMI audio out.
The ATI 4850 has DVI ports on the card, however, it comes with a "special" dongle that converts DVI to HDMI WITH sound. I'm not exactly sure what this thing does, but I do know it's not a regular DVI to HDMI dongle.
Anyway, so back to my question; the DVI Dective doesn't have HDMI ports, they are all DVI. What I want to know is how/what cables do I need to make this work.
This would be "cleanest":
4850 -> DVI -> DVI Detective -> ATI DVI to HDMI dongle -> AVR
However, I'm not sure if the 4850 will see that dongle the "right" way if it's connected through the DVI Detective; ie, will my sound still work?
Here's the most certain to work:
4850 -> ATI DVI to HDMI Dongle -> HDMI to DVI converter -> DVI Detective -> DVI to HDMI cable -> AVR
However, that's a ton of cables, and really ugly; I'd like to avoid that if possible.
Also, what type of DVI cable can carry audio? Do I need dual-link, DVI-I, DVI-D, etc?
I'd appreciate any advice, and certainly, if someone has the 4850 with a DVI Detective, please let me know how you have it connected!
Thx!
Thx!
