AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › do NOT buy monster cable turbine rca cables!!
post #1 of 17
I bought 12' THX monster component video cables off of ebay and i can't stand the stupid "Turbine" connectors ... they require a ridiculous amount of force to apply and remove.... i feel like i'm going to break something..
how could they possibly think this is a good product
/rant
post #2 of 17
Thanks for saving me monies. Even though everyone says not to by monster cables I needed 1 more person to reassure me.
post #3 of 17
i don't have anything against monster cable just those stupid turbine connectors...
p.s. i realized after the fact that i probably posted this in the wrong subforum... sorry
post #4 of 17
Monster Cable in general is not popular here at all. Especially considering the alternatives at Monoprice, BJC, etc.
post #5 of 17
I agree, I have a pair of 3 component and they are annoying to take on and off. I feel like I'm gonna knock my TV over.
post #6 of 17
To insert... push while twisting clockwise
To remove... pull while twisting clockwise
They are a good product, just highly overpriced.
post #7 of 17
nope they still suck... the shroud spins so you can't twist them..
post #8 of 17
If only I could find $200 component cables that DIDN'T have turbine connectors! Hmm....
post #9 of 17
if you want some that badly, i'm sure i could make some... maybe even $500 ones...
post #10 of 17
From the Mon$ter FAQ's:
What are "turbine" connectors?
Monster’s unique turbine design allows for maximum contact pressure, contact points and contact mass, all of which are highly important for signal transfer. This design also adds strength and durability. It is often helpful to turn the connector clockwise, to the right, when plugging in or removing the cable.
If the shroud "spins" with yours... perhaps that's why you got them cheaper on EBay?
post #11 of 17
I wouldn't be surprised to find that they're not even Monster, but Chinese knock-offs.
post #12 of 17
you should just remove the last 3 words of the thread title
post #13 of 17
If the shroud spins, perhaps it is come unscrewed. If you tighten it back down, you should have no problems twisting them clockwise. Not that I'm condoning monster cables.
post #14 of 17
yea they were just loose but it didn't help...
there's just no reason for them to be that tight
post #15 of 17
/rant
I prefer the straight and easy RCA phone jack lead cheap leads and I mean cheap haven't had a single issue not one, well I'm mostly using XLR now and that gives a tight enough fit without the hassle. I solder my own XLR leads up piss easy and the amount of money you'd save is incredible.
When I saw those Monster THX cables at Maplin electronics down Bournemouth Square a year and half ago I, was all most tempted to wasted £25.00 pounds for mere 1.5meter length, daylight robbery, daylight robbery.
post #16 of 17
hmm, I have the 3-component set and they are connected at the ends. Makes it kind of hard to spin them while you plug them in. I don't have enough fingers to spin 3 cables at once...
post #17 of 17
I hate to admit this but I actually broke off the "Y" connector from my old display with component cables like these. If placed back in there would still be an image, but it was distorted with horizontal lines moving across the screen, etc.
  Back to Forum: Cable, Digital Cable - Non-HDTV
