AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Sound Card and Receiver question
post #1 of 3
Hi
I just bought a Asus Xonar DX sound card (my mobo only has PCI-E 1X open no PCI).
My question is: Do I still need a dedicated receiver like an Onkyo etc, to hook up 5.1 speakers (not PC Speakers but real ones )
OR
Can I just use a decent amplifier?
I think the receiver will make the sound card an overkill.
Any suggestions will be highly appreciated.
post #2 of 3
If you run analog multi-channel cables (a "snake") from the card analog outs to the receiver, then you just need a good multi-channel amp (and speakers).
If you run digital out (Dolby Digital Out) then you still need a receiver that can decode Dolby Digital.
post #3 of 3
If I run the Digital Out and let the Receiver decode it, then what is the point of an expensive card? Can I just use one of these?
Ebay Id: 180294893604 (sorry cannot post url)
Thanks for the reply.
