Hello all! After many years of using my current equipment in an open finished basement arrangement and several months of reading these forums, I've decided to partition the room and build a dedicated audio and HT room. Being a TOOL fan and having to disassemble, box, and relocate everything to other parts of the house, hence "flush it all away", I came up with the AENIMA Cinema. I will post pics and answer questions as the teardown and rebuild progresses. And I'll have questions for the experts as well.
YaboTech
YaboTech
and I do believe AENIMA is one of there current songs
Was the Yes show "In the Round" with the revolving stage?
HVAC duct is attached to the I beam that intersects the middle of the room. Also notice unistrut attached to underside of beam and floor joist to hang crt projector. I've given the ceiling issues; sewer, I beam, HVAC duct a lot of thought and many hours researching the forums for work arounds. RISC clips and hat channel then drop down to frame out HVAC duct then back to the clips for the back side of the beam. I've read that wreaks havoc on high end audio listening versus a constant height ceiling. Maybe clips behind the I beam to raise the ceiling for the back seat riser. I'm leaning toward double top plate framing and running 2x8 across the theater room for the DD & GG. Basically room within a room construction for as much decoupling as possible. All comments and suggestions welcome.
