I am building a HTPC that will also be used for gaming. I need some ideas for good looking/small cases that will also house a full size gaming card (most likely HD4870 1GB).
hmm, I use antec fusion and that fits the 8800GTS no problem, however if your card is longer than the motherboard then it wont fit. If the 4870 is then maybe the antec fusion max might be the case for you
You Think The Normal Antec Fusion would fit in an ATI 4850 + Asus P5Q Mobo?
