It doesn't work, that's why I don't use it. There is very little support for newer motherboards and you end up being a beta tester unless you can find an ancient mobo that has been given their seal of approval. In fact, I couldn't find one "officially approved" mobo for sale on NewEgg - plenty that have been discontinued. unRAID doesn't support the AOC-SASLP-MV8 either. I think probably some of the lack of support is Linux/driver related. That's a big part of why I don't think unRAID will be competitive in the future - it's a product you have to pay for but they rely on an open source OS for it to work. Once it supports my hardware perhaps I'll give it a try.
Originally Posted by Piglover
For 99% of the readers of this forum, all they need is a large, reliable server that can hold their media library, survive single disk failures every time, and handle 3 or 4 HD streams simultaneously. Meeting these requirements does not need the expense or hassle of hardware raid (ever...). There are several good solutions to this, depending upon your experience and personal preferences, including WHS, unRaid, and a few others. The discussion of one vs the other are largely religious in nature and not worth spending any time on...
I agree with you... except the last statement. I don't see why discussing the options has to be fraught with bias. In fact all solutions have disadvantages as well as advantages and I likely will choose the solution that best meets my specific needs - of course that doesn't mean the others are better or worse solutions - just different.
Hardware RAID: great performance but too $$$ and probably the wrong tool for the job. Why buy a Porsche if you only want to haul lots of stuff? The analogy isn't perfect but makes the point.
unRAID: cool features, unified share, inexpensive and relatively simple. Unfortunately it supports old hardware... perhaps that's part of the reason it's so slow and requires a landing drive. You have to pay for a license that's tied to a USB drive and if that fails you have to get a new one - if the owner drops support of the product you're out of luck. It's based on Linux so expect it to fall further behind as far as driver support.
WHS: unified view, built in WHS featuers (i.e. computer backup), full OS can be used for other tasks. Unfortunately, it's expensive because fault tolerance is based on folder mirroring and thus isn't a great value.
FlexRAID: cool features, inexpensive, supports any hardware, and has high performance. Unfortunately, it's current version doesn't support WHS (for unified share) and there's risk using it with that OS (tombstone issues). It's snapshot RAID which leads to those issues. It will work on other OS's, with any hardware, but a single pooled share is what many people want and you need unsupported WHS for that.
So, for me it's not a matter of religiously believing in any of the solutions but rather choosing between very imperfect options - the one with the least problems.
I've changed motherboards 3 times without loss of data as Hardware Raid cards handle the array configuration data not the motherboard. If you have a card fail you can get the same brand card and not lose anything. True, You could lose data if you have a motherboard failure using it's built in software raid, but then again if you can get the same motherboard or one with the same chipset you may be able to save the data.
