Originally Posted by globetrotters1
well, I have two Norco 4020 cases, one with the M/B and the Areca 1680-ix-24 controller and one with the Chenbro-13601 expander (which is not yet 'in action'). I use 11 WD15EADS drives, 5 drives for media storage RAID-5 (streaming music and videos), 5 drives in the second case finally as a backup RAID-5, 1 drive as a hot spare in case something fails. Then I have 16 Samsung 500GB drives which I want to use further on (8 drives each in a RAID-5 array, one online, one for backup in the 2nd case - second case is only on if I want to do a backup, weekly). And I have 3 WD 640GB AAKS drives for media preparation purposes, used as simple drives in the main case.
In the future I want to extend the arrays 2 WD15EADS at a time as soon as the used storage space reaches 80%.
That's more or less the idea...
Thoughts?
Oh, and just as a remark: I switched the RAID driver from STORport to SCSIport... now the speed has increased slightly to 70-90 MB/s
Thoughts?
Ok, that's a lot of drives and arrays but ...
Set your stripe size on the areca to 128K.
Then when you format the volumes in windows use 8K clusters for arrays that will be under 32TB and 16K for arrays under 64TB.
Here's a table of NTFS cluster size to max volume size that you might find useful.
p.s. don't use scsiport. storport is the preferred transport.
post the bench when you're ready and we'll go from there.
