Originally Posted by starcat
Ok, I think I am narrowing my search down to the following components to be fitted in my new 4220:
- 1x Supermicro X7SBE
- 1x SFF-8087 to 4 SATA reverse breakout cable for onboard slots
- 2x Supermicro AOC-SASLP-MV8
- 4x SFF-8087 to SFF-8087 cables for HBAs to backplane
- 1x Corsair HX750
Looking for a chip and memory. I think 2x 1GB is more than enough?! Memory is DDR2 800Mhz 240-pin DIMMs.
Super micro says they support following CPUs with the X7SBE, which one to choose? The slowest E4000 should be probably ok?
- Intel® Core2 Duo E8000/E7000/E6000/E4000 series
- Intel® Pentium® E5000/E2000 series
- Intel® Celeron® E1000 and 400 series
- 1x Corsair HX750
If you are dropping UnRAID as your OS you don't need a board with PCI-X slots to use the older SATA cards. The board you have will work, but I would go with something with a little more PCIe expandability if I was you.
What OS do you intend to use? And what RAID system/type? Really you need to nail down exactly what it is you want to do with your hardware before you pick what that hardware is going to be.
. Let's assume you have 100 files per BD/DVD title. If you have 1000 movies stored on your array, that is 100,000 files. Assuming we wasted half a cluster on the average, that is 32,000*100,000 = 3.2 Gigabytes. For BD, storing 1000 titles will take an array that is probably 35 TBytes or 35,000 gigabytes. 3.2 Gigabytes would be round off error in that. Double or triple that and it still means very little. Considering that you always have some loss even with smaller cluster sizes, the penalty is actually less than it seems.
