Couple of quick questions. Took a couple days to get caught up on this thread, but I got a few ideas, and before jumping to any conclusion, a little counter thought might prove useful.
My current media server is WHS with an OS drive on the motherboard controller, then a 3ware 9690SA to a Chenbro CK12803 with 15 1tb drives in RAID5, I'm exporting in 2TB slices to the OS since WHS is fairly retarded about large arrays.
I'm down to 4tb of free space and at the rate I purchase Blu-Rays, expansion is not far off. I caught up on this thread to hopefully get an idea about who is selling drives cheap, well that didn't happen for me with 1tb drives, but I did get an idea about 2tb drives seem to be quickly dropping in price and per byte costs are now well under 1tb drives, so while I would need to expand to a 2nd chassis, populate it with 2tb drives, then remove the slices from the original RAID5 array, WHS would migrate the data to the new array using the 2tb drives, and rebuild/expand the original chassis with more 2tb drives and sell off the 1tb drives for whatever I can get.
Now this will keep my data intact while migrating it, but this also needs to hopefully solve an issue I've had ever since I built this box, which is that dang balancing act WHS does every hour. If it happens when I am watching a movie, the stream stutters for a short period then back to normal, if I move the data to the local node playing it, no issue, so it is deffinatly WHS. My thought was could/should I build this new array of 16 2tb drives as RAID6/10 (or 2 8 drive arrays for that matter). I'm looking for a smoother stream, and obviously more space.
I just recieved a Chenbro UEK and before I order anything else, just want to explore my options.
and I have two of these.....
) has ironed out some of the bugs that were there in the initial release, it may be time to revisit it again. Again, the new plan's basic underlying assumption is that we're not building a high performance raid/san system. We're build a storage system primarily for storing media, and have some redundancy, so that if a disk crashes (and it will) we don't have to re-rip everything that was on that disk.
