Originally Posted by MikeSM
I think the better deal is something like the TYAN S5211G2NR or the Supermicro MBD-X7SBA. Socket 775 CPU, normal DDR2 ram, and 2 PCI-X slots as well, plus a couple intel GbE ports. You can find them for about two hundred dollars, and you get 6 onboard SATA ports to boot. Add two of the 8 port SATA PCI-X cards, and you have 22 SATA ports, which fills up a norco 4020 well (with one SATA port for a system disk and the other for a slim optical drive). And the tyan has a couple PCI-E x16 slots to boot. They are both P35 based, with ICH9R SATA ports, so they are very fast onboard ports and well supported in DOS (er.. windows) and Linux.
The Socket 775 CPU's are much cheaper than the socket 771 models for the same performance, and no expensive FBDIMM's required, and these boards handle the latest 45 nm CPU's too. Alas, no overclocking capability...
PS And the tyan comes with a cheap onboard video controller too. :-)
I think you guys going the socket 771 route with FBDIMMs are really throwing money away.
I disagree Mike, the chipsets used in the 771 boards, especially the 5400, are far superior to the 3000 series chipsets used in the 775 boards, and the prices aren't even that much different. With a 771 board, you have the "option" of adding a second CPU if need be, and the ESB2 is just so much more better than the Southbridge/ICH in the 775 chipsets.
But I do agree that if cost is a concern, you can find some of the 775 boards real cheap, and not everybody needs 8 cores.
Lol, that's 20 disks right there.
