Originally Posted by StardogChampion
1. Via the disc install, you will need a minimum 160GB partition to install WHS. There are ways around that if you Google them. In addition to the OS it creates a SharedFolders directory.
2. Sorta. They won't be in the shared folders. You cannot simply point the shared folders at the drives. You'll need to move the shared folders via the dashboard to where you want and copy the data into the folders from your old ones. I guess you *could* point the shared folders at your existing ones via symbolic linking but me, I'd just copy your existing data into their structure and be done with it.
Apparently, the designers for WHS didn't think you'd want to simply point the shares at an existing folder.
So here is where I am confused. Do I just install on the 2TB drive and then it makes its own partition? And I can use the rest of the drive as the Shared Folder Directory like regular storage?
Can you explain #2 a little more? Should I move the data from the 2 other drives onto something else and then do all of this?
I am moving 1.2TB of data off one of my drives as we speak to get it empty for the WHS install. This is the same drive that has my 120GB Win7 partition.
