Originally Posted by bryansj
I just installed WHS 2011 on a 64GB SSD last weekend and other than creating the custom cfg.ini on a USB stick there was no other tweaking required. It worked out well for me since I was going to add a drive pool to D: so it was simple to move the serverfolders from C: to D:. Otherwise using the default 160GB minimum HDD install the serverfolders are already on D: so putting the pool there is more of a pain.
FYI, open Notepad and save this to a file named cfg.ini onto an NTFS formatted USB drive:
[WinPE]
ConfigDisk=1
CheckReqs=0
WindowsPartitionSize=MAX
Boot up the install disk with the USB drive inserted and your install will be placed on your < 160GB drive on a single partition.
[WinPE]
ConfigDisk=1
CheckReqs=0
Right. That would be "some tweaking".
You also should remap the default shares.
