Originally Posted by Mfusick
If your drives are not SSD and are only HDD then it does not matter and the above advice is not accurate.
While I generally put SATA3 HDD's on SATA3 ports when possible... for HDD it would not matter if you had a SATA2 port with a SATA3 HDD on it. The performance is the same.
Normal HDD's can not fully saturate a SATA2 port so there is no difference with normal hard drives if you use a sata2 or sata3 port.
The results are the same.
Only an SSD can fully saturate a sata2 port. Put your SSD on that.
The rest don't matter.
EXPLAIN EXACTLY WHAT IS NOT ACCURATE?
Connecting a SATA III drive to a SATA II port and only getting a SATA I connection speed does matter. I have seen this occur with both onboard ports and addin controllers.
