AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon AVR 888 or Denon AVR 2808CI for PS3
post #1 of 6
I'm at a toss up for these two and am trying to decide between them. I'm going to be using a ps3 for blueray most likely. I need some input as to if it worth the extra $220 to go up to the 2808ci? Thanks.
post #2 of 6
your decision should also factor in your speaker setup too. if you need a heavier setup then you should lean more toward the 2808. on the other hand if you have a circuit city in your area you should consider the "deal" they have on the newer 889. check out the 2309/889 thread.
post #3 of 6
L/R Polk monitor 70's
Center CS2
4 Monitor 30's for the Surrounds
no woofer yet going to get an ED one though.
is the 889 more closer to the 888 or the 2808?
post #4 of 6
The 888 is for only $365 on amazon and since you have a PS3, you shouldn't have any problems with the latest HD audio because the PS3 will do the decoding for you. I myself am planning to get this receiver. Can't pass up on that price.
post #5 of 6
Hello all, excitted I have found a great place for help and information! I have a denon AVR-888 with a polk CS2 center speaker, Polk M50's for the fronts and polk RC80I's for the rear surrounds and a velodybe dps 10 for the sub. I hope to get everything set up this week. The TV is a sony Bravia 52" I will also be hooking up a PS3. My biggest question is what is the best way to set up the sub, I was going to use the LFE input and set my other speakers to small? Does that sound correct? Thanks for the help and please forgive if I posted this in the wrong place...
post #6 of 6
I just got my subwoofer and hooked it up to my receiver but I get zero output...any ideas?
I have a CSX-15 and no tv hooked up right now...I just want the sub to play but it isnt....
please help
the csx.15 has a left and right I have the y cable that came with hooked into each input...i then have one rca cable going to my pre out subwoofer input on my denon
