The CNET review stated that the 'Smooth' mode did not work with 1080p sources on the PN63A760. Should that be expected? Doesn't the "de-judder" mode on other sets work with 1080p sources?
Can someone who has this set verify this? Also, if you can enable smooth mode with a 1080p source...how does it look? Noticeably different like the de-judder mode on LCDs? They usually offer different levels of adjustments too...
"We also checked out the Smooth mode on the PN63A760. For some reason it doesn't work with 1080p sources, so we switched our PS3 to 1080i output and compared it with the dejudder modes, also titled Smooth, on the Sony and the Pioneer. In general, the Samsung worked as expected, eliminating much of the judder associated with film-based material. It also introduced its share of artifacts, including some separation in fast-moving objects and the "halo" effect, which appeared primarily during fast movement onscreen or camera movement. One example occurred in the beginning of Chapter 15, when Moore's helmet seemed to break apart as he quickly glanced down, and a bit later when a halo formed behind a quick moving soldier. The dejudder effect also seemed to kick in and out rather abruptly, such as during a quick pan around Moore's wife's house that went from smooth back to judder in a relatively jarring way.
Since many viewers who can afford this TV will likely feed it 1080p sources, however, Smooth is much less relevant than it would be on other displays. We also checked out its effects when watching non-film-based (native 60Hz) material, including a hockey game, and we couldn't see any evidence of smoothing, nor any difference between the Samsung and the other displays. The PN63A760 lacked any trace of the "triple puck effect" seen on the dejudder modes of some of the company's 120Hz LCDs."
