Is your Sony shutting itself off and blinking the red led 4 times? Guess what? It's the fan...
Don't waste your money buying a new one, I have the absolute easy fix:
This is a fan issue, most likely the large fan in the rear, lower left (from the back)...
Here's the fix, I promise, it's EASY........
Ok, I think I have the answer for the BIG FAN failure. I recently did a similar fix on the spindle of an xbox 360 and it is identical. Ok, this is an EXTREMELY EASY FIX...
Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.
Once the fan is removed, you will see the side with the model number and the other side is totally open.
On the open side, pull...
The fan will come off, into your hand, it is only held by magnets...
You will notice a spindle on the fan and the other side has the magnets and the hole where the spindle came from (this is the fan motor).
Clean both the spindle and the hole (motor) with a q-tip. The hole is smaller than the q-tip, but do the best you can to remove the old lubricant.
Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.
Put them together, reconnect your fan, test it on start up and thank me...lol...
HOPE THIS HELPS!!!!
IT WORKS, TRUST ME...
HOPE THIS HELPS!!!!
I used PB blaster instead of WD-40. To be safe, I just sprayed a tiny amount on the spindle and wiped it with a clean paper towel. I didn't want to risk putting any in the hole for fear that it could ruin it. I don't know how much longer mine will last, but I was at least able to put a movie on while having some family visit. Thanks again!
