AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Official Planar PD7130 owners thread
Official Planar PD7130 owners thread - Page 6
post #151 of 1578
If anyone is going to have a problem with the lense shift parameters don't forget to gain clearance by tilting the projector(then tilt the screen the same angle so they are perpendicular).
For example a projector 11" from the screen, every degree tilted will
gain 2 1/4" in lense height clearance.
post #152 of 1578
What about straight on...can it be "in the screen range"?
Angling isn't an option in my set-up. Ican mout it at the top edge or above, but it would be much easier to mount say 5'/6' up insttead of say 7'/7.5' up.
post #153 of 1578
Did anyone happen to see if the 7130 has the darkchip 2 or 3?
post #154 of 1578
Dc3
post #155 of 1578
Originally Posted by E-A-G-L-E-S View Post
Is it possible to have the lens within the height of the screen and not just above or below it or even in-line with top or bottom edge?
I got my 7130 yesterday and its mounted close to the center of the screen. With the len shift I could center it
post #156 of 1578
Did you mess around with the vertical lens shift? If so, how far upward and downward were you able to shift the screen?
post #157 of 1578
Awesome......thanks!
Only problem is I don't get mine until friday?! And I have invited several people over for a big movie night on thursday. Since people got theirs as early as monday night I thought I'd get mine by thursday at the latest.
post #158 of 1578
AGHHh... Mine is now showing Friday as well. Originally was Thurs...
This is my first projector... so I am a wee bit excited for it. Just checked my cables from monoprice and they won't be their until Monday... UGH
post #159 of 1578
My projector just arrived. woo--hoo!
damn this thing is big looks like 2x the size of my in72. I don't know if my ceiling mount will hold it.
I will be hooking it up to test shortly.
post #160 of 1578
Well, I admit i'm a little dissapointed with the lack of offset. I have a vaulted cieling so mounting it means having a long drop from the cieling. I just assumed that lens shift would include significant offset.
So here is what I'm thinking: Some sort of actuator to raise and lower the projector. If i can use the 12v trigger on this as well as the electric screen that'd be pretty neat. I'v got some attic space above that I may have to use. Interesting.
Sure it'd be less work if I just got a larger offset pj, but not nearly as much fun.
post #161 of 1578
yea the up down offset is limited.
picture quality looks good so far.
post #162 of 1578
How does it compare to the IN72? I am upgrading from the IN72 as well.
post #163 of 1578
well colors are poping more.. though my bulb was old..
much higher resolution.. tighter pixels as expected..
and big n heavy.
it is quieter.
the biggest challenge will be placement.
post #164 of 1578
http://www.newworldvideodirect.com/p...ProductID=1035
Looking at this for a warranty for the bulb.... does anyone have any experience with these warranties? I have bought extended warranties on equipment before only to find out that it is almost impossible to get the item repaired/replaced once it needs it due to loop holes.
This warranty seems way too good to be true. 125 bucks and they replace 1000 dollars worth of bulbs?
post #165 of 1578
OK this thing is a beast.
It weighs 17 pounds vs the 9 of the IN72.
My question is.. any advice on what i should use to mount this thing?
I'm afraid my previous mount might rip out of the ceiling.
post #166 of 1578
There is also this one for $70, I don't have any experience with either company though.
http://www.newworldvideodirect.com/p...ProductID=1001
post #167 of 1578
Your mount should be anchored into a ceiling joist. If that is not practical, you will need to create a plate that can mount to ceiling joists and mount your ceiling mount to the plate.
post #168 of 1578
I bought a generic universal mount from ebay, which states it holds up to 33 pounds. As long as you have the mount anchored into a stud/joist, then you should be fine. If your mount is hanging on to drywall on the ceiling, then you're probably in trouble.
post #169 of 1578
and big n heavy.
it is quieter.
Are you running HD signals, Blu-ray, HD DVD? How much better do they look?
post #170 of 1578
yea im going to have to find that beam.
no fun.
post #171 of 1578
I dont have blue-ray yet.. but I will say it looks good.
post #172 of 1578
no fun.
Most hardware stores should have a cheap stud finder.
post #173 of 1578
I only was able to get one side of my mount into the joist (2 screws), hopefully that's enough to support the 17 pounds.
post #174 of 1578
Depends on the screws in those two positions and the anchor you used for the third screw.
post #175 of 1578
Another thing to consider with the mount (at least in my case) is that I WILL bump it at some point so the mount must be secure.
post #176 of 1578
I could shelf mount it, but with the lack of offset I don't think it will work at 7feet 6 inches up.
post #177 of 1578
The ceiling plan will work, just use good quality wood screws that will support the weight and use a good drywall anchor for the third screw. You should be good.
post #178 of 1578
Why not mount off the rear wall?
post #179 of 1578
I just got my projector and fired it up to play with it. The first thing I noticed is that right out of the gate it has some pretty bad horizontal keystoning. Is anyone else having that problem? I really hate the idea of having to mess with keystoning when my projector is facing the wall straight.
Of course, this is my first projector so I have no idea if this is common or if I have a broken projector.
post #180 of 1578
My living room does double duty as my home theater. Since it is 21' by 17' with vaulted cielings, I have always just used the coffee table with my short throw DT-300 and put it away when not in use.
Since the throw on the planar is a little longer, I had hoped to cieling mount it. There are a couple interesting threads on DIY projector lifts i might try.
Until then it looks like i'll still be using the coffee table.
