Originally Posted by two-rocks
Something is not adding up which explains why it was a WOOT deal....
If I choose I 100" diag screen, the zoom range only allows the front of the projector lens to be 10'1" to 12'7" - for the mathematically challenged - that's the front row in most theaters.
Add to that the lack of lens offset puts the projector somewhere between 5'10" and 6' high off the floor (ceiling mounted, but using the floor as a reference).
Good thing the cables are hidden, cuz this POS just took over the 'LOOK' of my HT. Can you tell I'm frustrated?
Just a thought, but you may be jumping the gun and it may turn out differently than spec'd, like my pd7060.
If that got that good of reviews, I'm sure the 7130 will be great, especially at a $599 price point.
