Looking for a specific light
post #1 of 5
It is light the ones you see in hospitals that you plug into a outlet and when their is a power failure that light comes on due to the battery. Where would I buy this for a residential home, hopefully one that looks better also.
I think that I have seen it on this forum, it is actaully a nice rounded light design that fits into the battery and can be pained. Thanks.
post #2 of 5
I picked up a 3 pack of emergency lights at Sam's Club. These are probably not exactly what you are looking for but what I liked about these are that they plug into a standard outlet, they turn on when the power goes out, and they are unpluggable so you can carry them through the house as a flashlight.
I suppose the point is, is that any big box store should have some emergency lights and then there is always google.
best of luck.
post #3 of 5
What do you want it for? I ask because I have one that not only turns a light on upon power failure, but it ALSO beeps an alarm. I use this so I am awaken if there is a power faliure, and I can check the sump pump on the basement, switch my generator on, etc....
post #4 of 5
Incase of power outage.
post #5 of 5
Just do a search for Emergency and Exit lights on google:
https://www.exitlightco.com/SFNT.html
I would also recommend that anyone who's going to the extent of emergency lights should probably be prepared enough to have a quality Med Kit, and Fire Extinguishers for their home.
