AVS › AVS Forum › Video Components › Home Theater Computers › how do you ripped BD movies into hd?
post #1 of 5
i want to know if my system can ripped blu-ray movies into my hard drive?
AMD phenom 9850 + biostar 790gx + 4 GB of DDR2-800 ?
i just want to ripped movies with subtitles and not the extra.
of course i need a blu-ray drive, what program do i need to ripped it? also how long will i take to ripped it?
post #2 of 5
http://www.avsforum.com/avs-vb/showt...ghlight=eac3to
Just started using the process explained in that thread 2 days ago and it works great. Takes me about 40-60mins to rip a blu-ray movie depending on length. Then another 15 to mux everything back together. I've got a E8400, and 4GB RAM using Vista x64.
post #3 of 5
is there any easy way to ripped the movies into the hard drive?
post #4 of 5
The AnyDVD HD Ripper will rip BDs to your hard drive, but you get more than just the main feature.
If you want simple, that might be your tradeoff.
post #5 of 5
I use PS3 o rip BD movie into HDD in iso format. It takes about 6 to 8 hours to rip.
