AVS › AVS Forum › Blu-ray & HD DVD › Dual Format Players › BH200 and BD-R and Video
post #1 of 5
My BH200 will only see BD-R with video on it as data.....it is burned properly with ImgBurn and proper file structure (udf 2.5, etc.)
anyone else try this? Does the LG NOT play BD-r and only see it as data?
post #2 of 5
Which firmware you using? April or June? June one doesn't work with BD-R.
post #3 of 5
the latest one.....so June.
Why did they remove BD-R...this means I cannot make home movie BD-Rs with my camcorder and play them....this is stupid.
Any reason why they did this? I gather I cannot flash back.
Has anyone complained to get this back.
post #4 of 5
You can flash back just fine. I did, because I don't like the color palette of the June firmware.
is there a direct link to April firmware somewhere?
thx
Well... It's on the same page as the June firmware.
post #5 of 5
thx
  Back to Forum: Dual Format Players
