OK - So since there aren't enough threads on the topic of video projectors anywhere on AVS (just kidding of course), I figured I would start my own. I am probably wishful thinking here, because, (A) I doubt I would find a buyer for my existing projector and (B) I can't justify setting my existing projector aside to upgrade. BUT the bug has bitten me and I wanted some feedback.
First, my screen is scope and is 15' wide. The first proj I used in the system was a Highlite Gold High Contrast from Digital Projection (1280 X 1024). I used the lens zoom memories to refocus, zoom and shift between 16:9 and 2.35:1. After unsolvable problems with that unit and not being able to fix it, DPI graciously swapped me out with a Titan HD-250 (1280 X 720), ISCO III and Cineslide. My problem is, for some reason, pixel structure was not visible with the highlite but it is with the Titan. It's not so much that I can't enjoy movies in my HT room but I think I am pushing the resolution beyond it's preferable limits. On a smaller screen, I think I would be fine. In fact, I have zoomed the image down to about 11' wide and it looks stunning. But, hey, I have a 15 foot wide screen, a big room and I want to fill the freaking screen.
Assuming that I can't sell my projector, what would fill a screen that size in the $15000 or under range. The more under the better. Obviously we are looking for 1920X1080. The room is completely light controlled. I will be keeping the ISCO III so that would still push be over the $20000 mark required for this forum.
I can honestly say that if I can get the projector situation ironed out I will be satisfied with my system for at least the next 3 months.
Chris White
Chris White
You must consider bulb ageing into the equation to avoid disappointment 200 hours down the road IMO.
