Originally Posted by Tarheel72
What do you mean by this? I have a HK635 and use the same set up as you for audio. I run video direct to the 1080P TV with HDMI. I am using a Samsung 1200 set to upscale everything to 1080P, which takes advantage of its outstanding Reon processor. Are you saying that you have to set the 550 to do no upscaling and send the 480i signal to your video process so it can perform that function? In that case, we still do not know what kind of job the 550 does in upscaling a SD DVD. I want to see how it compares to the Reon in my 1200. I would like to have an all in one machine, but if I have to I can keep the 1200 hooked up for the occasional SD DVD that I pop in.
Yes, I am running 480i through the DVDO and it is performing the upscaling. The picture I am getting is better than the 480i through the DVDO with the Samsung. I will have some time today and I will bypass the DVDO to assess the Sonys upscaling abilities.
