AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › The Official Sony BDP-S550 Owner's Thread
The Official Sony BDP-S550 Owner's Thread - Page 11
post #301 of 3961
Originally Posted by Kenrosencpa View Post
My processor only has 5.1 analog inputs, no hdmi. Is there a setting to output 5.1 analog or do you do 7.1 and ignore the rear channels?
thanks
Ken
The S550 has a speaker settings option when you have chosen "multi channel
analog" as an audio output preference. In the speaker settings you can turn off the surround back speakers...which I think will tell the player to decode and downmix to 5.1.
post #302 of 3961
Originally Posted by netjazz View Post
Can the Sony BDP-S550 in some way handle still digital photos like the Panosonic even without the card slot? Not a deal breaker, but a handy gadget.
Figure the PQ will be about equal on both, but what about good old fashioned stereo 2 speaker sound?
I believe it will play photo CD's and DVD's.
There are 3 things I wish Sony would have included:
1- Card reader
2- Source direct
3- Frame advance after pause
But none were deal breakers for me. It give excellent quality picture and sound and that is what really matters!
post #303 of 3961
Originally Posted by epontius View Post
Otherwise you will only get the lossy core DTS 5.1 decoded to LPCM and not lossless DTS-HD MA decoded to LPCM. Apparently a technical limitation of the current player.
Thanks. What would the "mix" contain? That is, does it apply only to audio from outside sources like downloaded from the Internet, or can it apply to tracks on the disc itself?
post #304 of 3961
Thanks, I just bought one. Got a good deal see here http://www.avsforum.com/avs-vb/showt...1#post14859937
post #305 of 3961
The "mix" setting will mix the program audio with secondary audio. For instance, Resident Evil: Extinction has a "bonusview" or "picture-in-picture" video commentary with the director, storyboards and such that runs in a little window on the screen. The audio of the director in the video is mixed in with the program audio. However, the S550 will only decode the lossy core DTS 5.1 audio and mix with this secondary audio and then output through multi-channel.
However, it does this with all DTS-HD discs regardless of whether a secondary audio track is enabled or even exists on the disc.
So setting the "BD audio" setting to direct, outputs just the program audio but it decodes the lossless DTS-HD tracks to LPCM. Obviously if you enable the visual commentary on the disc you don't hear the secondary audio at all. That is essentially the only downside to changing from the default "mix" to "direct." Small price to pay for DTS-HD decoded to LPCM.
I should point out that this only seems to happen with DTS-HD and not Dolby TrueHD.
post #306 of 3961
You will never get lossless over coax or optical since it is beyond their capabilities....you can only do this with HDMI 1.3a. Since your receiver won't do audio over HDMI, you'll have to rely on analog input on your receiver.
To get multi-channel DTS-MA decoding to LPCM through the analog output do the following:
On the S550, change the Audio Output Priority to "multi channel analog". Change the Speaker settings to set the speakers according to your config, set the surround back speakers to None.
Set the "BD Audio" setting to "direct"
Connect 6 cables to the analog output of the S550 to the analog inputs of your receiver. You will get 6 channels of LPCM.
Just to be clear here for my understanding...Lossless can be done via HDMI or by using the 7.1 analog outs, not by HDMI only right?
post #307 of 3961
OK, got it. I had most of the audio situation figured out, except for that final piece. Thanks for the complete explanation.
Now to wait patiently for the S550 to arrive...
post #308 of 3961
To add to the confusion I got this reply from Sony when asking about lossless over the analog outputs:
Hello,
Although the BD550 does decode the new audio codes, you would need an HDMI input in order to do so.
Devon
Sony Style Concierge
post #309 of 3961
Yes. There are three ways.
A lossless track can be sent as bitstream over HDMI 1.3 for decoding in a receiver. The receiver must have HDMI 1.3 and the proper decoders. The AVR will do the digital-analog conversion.
Or, it can be decoded in the player and sent as multichannel PCM to a receiver with HDMI 1.1. (Some receivers with HDMI 1.1 only accept 5.1, not 7.1. And some only do video switching.) The AVR does the digital-analog conversion.
Or, it can decoded in the player and converted to analog in the player. The player sends analog audio for each channel over a separate cable to the receiver.
post #310 of 3961
Gotcha, thanks. I just bought Gold Compass (DTS HD-MA 7.1) and Iron Man (Dolby TruHD 5.1) for my panny thats coming in tomorrow. I still need to find or buy some rca's for the outputs. All I see for sale is Component video/stereo packages.......would this be ok even though 3 of them would be used for audio instead of video? I have a set of audioquest rca's for the two back surrounds.
post #311 of 3961
Component video cables will work fine. Video cables are the same as audio cables, but rated at 75 ohms to provide the necessary bandwidth for video. Many people order from forum sponsor monoprice.com. Their "premium" audio cables cost $3/ pair.
post #312 of 3961
Hi All,
Looking to upgrade my BDP-S300 to the 550. I was wondering if some kind person could confirm if you set the output to 1080i it will output to HDMI and component simultaneously? My reading of the manual seems to indicate that it would, but confirmation would be good. The BDP-S300 does do this.
Also, any thoughts on the component output of this player?
Stephen
post #313 of 3961
Hello,
Devon
This is a new player. I've contacted Sony Support several times and I can assure you that they are not familiar with this player. Most likely they have not been trained and their support resources not completely updated.
Having worked in tech support for a computer company for a number of years in my younger days, we rarely got enough training on new products before release. But then eventually caught up as more information became available and enough calls were logged to get a sort of knowledge base of common questions, workarounds, and fixes. Early adopters are often just a later stage of beta testing....
post #314 of 3961
Well... let me get this straight.
First of all, I have a home theater with a receiver with HDMI1.3 and decoding of all the lossless formats (Denon 3808). I am surrently using a BDP-S1 in here, so no access to DTS HD Master. Want to upgrade to BD-Live and lossless DTS.
I also have a BDP-S350 in my office for background noise and the ability to watch extras and things while I work. It's connected to a 19" Sharp LCD HDTV via HDMI. Obviously, I don't care much about lossless here. For this purpose, I am incredibly impressed with the S350... it is cheap, fast, incredible picture, pretty good upscaling, full BDLive functionality, great comfy remote (which works with the volume control for my TV), small, and damn nice looking.
If I understand correctly, if I get a BDP-S350 for the HT, I would have to manually switch between Mix (for listening to pip commentaries mixed with the soundtrack, lossy) and Direct (to bitstream top the receiver for decoding lossless, but not access to secondary audio stream). I also believe I will not get menu sounds, etc if in Direct mode. I couldn't care less if the soundtrack during pip play is lossless or not.
So I was looking to get the S550 so that I could leave the player in Mix mode (outputting PCM) and get lossless for soundtracks and still be able to mix secondary audio. However, it now sounds like you still have to make the setup change (Direct/Mix) to do this?
I also have yet to hear of any improvements in video or upscaling, and there is still no frame advance/slow-mo compared to the S350. Thus, it seems to me this eliminates the only benefit I (and anyone else with HDMI1.3 receiver) would have gotten with the S550. So basically only people that need the analog connections seem to benefit from the S550. Correct? Am I missing something?
post #315 of 3961
This player is just awesome. I love it!
post #316 of 3961
Originally Posted by wuberry View Post
I ordered from Crutchfield on September 29. I just (this morning) got an e-mail saying the expected shipping date was October 27.
Well ... It has apparently already shppped from Crutchfield, expected delivery is October 15, 2008.
post #317 of 3961
Or in the case of Pioneer 05/51, the consumer started the beta testing (Best Buy "leak") and still is!
post #318 of 3961
So far it appears that no one has had any issues playing any BRs. It appears that The Happening, released last week, would not play on many players. So I just wondered in anyone tried it on the 550 yet and what the results were? Or for that matter, has anyone experenced any playback issues with the player, using any BR?
I would also like to hear more comments concerning the upscaling ability of the player with SD, compared to your older player. thanks.
post #319 of 3961
Originally Posted by poddie View Post
I also have yet to hear of any improvements in video or upscaling, and there is still no frame advance/slow-mo compared to the S350. ...
Does the S350 have the frame advance/slow-mo? If it does, I might consider the S350 instead of the S550.
post #320 of 3961
No it doesn't.
post #321 of 3961
Leaving the S550 in mix mode will only get you the lossy core DTS 5.1 and not the lossless DTS-HD decoded to LPCM over analog or HDMI, and will not bitstream the lossless to your receiver.
post #322 of 3961
I played The Happening on the S550. Worked fine...even with the BonusView enabled.
post #323 of 3961
Hi!
Anybody have any idea on what happens when you play a DTS HD Master 6.1 track(XMen Last stand) when using a 7.1 configuration via the analogue`s.
Thanks in advance
Nick.
post #324 of 3961
The S550 is simply the S350 with a few more features, and I think by now we all know what those are.
However my guess is:
- It too probably doesn't have frame advance/Slow-mo (like the PS3 does)
- It too probably doesn't have Multiple Disc Resume (like the PS3 does)
- it too probably won't have a better quality DVD 1080p upscale (like the PS3 does)
post #325 of 3961
Originally Posted by pwiss View Post
For those using another scaling solution the Sony does give 480i over HDMI but you will need to change in the menu each time.
Ah bummer. So there's no way to set it to output 480i for SD DVD and 1080p for BD by default without having to futz with menus? Then it's just like S350 behavior -- less than ideal.
post #326 of 3961
Definitely less than ideal. But it takes less time to switch in the very quick menu system than it did for me to type out this response.
post #327 of 3961
- Correct
- Correct
- The S550 looks pretty good to me. I have both S550 and PS3 connected via HDMI to a Sony AVR and output 1080P over HDMI to a 60" 1080P SXRD rear projection. They both look good to me.
You forgot that the PS3 also has the ability to decode DTS-HD MA 7.1 to LPCM and mix with secondary audio from bonusview before sending multi channel 7.1 LPCM over the HDMI.
I think the usability of the S550 is better than the PS3. I have the PS3 BD remote (which is bluetooth) which allows me to control and navigate the BD menus and playback....however I still need the game controller to navigate the PS3 crossbar menus.
The PS3 also lacks bitstreaming DTS-HD/TrueHD (but does decode of course) and obviously doesn't have analog outputs.
Other than those they are pretty close... PS3 is a good box if you game and/or don't mind the controller/remote shuffle, and don't need multi channel analog output or can accept multi-channel LPCM over HDMI
post #328 of 3961
I have a Denon 2309 receiver, so I have HDMI 1.3 capability.
I'm considering the 550, the 350, and the PS3 for my BD. I have a few questions about them. Most of this thread is technical, at least for my knowledge of Home Theater (lossy, DTS-MA, etc).
I don't play games much, so I don't have a lot of use for the PS3 as a game machine.
However, from the last few posts, it seems to me that the PS3 is a very capable BD player. Other than the remote, what is it's shortcoming? Will it have just as good audio/video output as the 550? What does the 550 do that a 350 won't do?
I appreciate any help.
post #329 of 3961
- . I have the PS3 BD remote (which is bluetooth) which allows me to control and navigate the BD menus and playback....however I still need the game controller to navigate the PS3 crossbar menus.
I don't doubt that's true, but I've never found any functionality for BD playback to be missing with the BD remote. Sorry for the OT discussion.
For the poster above with an HDMI 1.3 AVR, the choice would be b/w the s350 and the PS3. The only thing the s550 adds is analog outputs and internal decoding which you don't need.
The PS3 will be faster but also has a bluetooth remote so there's some tradeoff there. There are aftermarket IRBT converters available or you can simply use either the supplied bluetooth game controller or get the add-on bluetooth BD remote.
If you plan to install inside a relatively confined space with less than ample ventilation, you'd probably be better off with the s350.
post #330 of 3961
Thank you very much.
This board is awesome. The only problem is there's so much info, it's hard to digest it all.
