Motion blur illustrated.
Recently on the forum, the issue of motion blur is stirring a lot of attention by folks like me for example who are very sensitive to this. Since my old CRT FP died on me early this year, I bought and sold 3 different PJs (Sanyo LCD/JVC RS2/Marants 11S2) and I have yet to find a display tech that handles motion as well as my old PJ. Some people are still skeptical and believe the topic of motion blur is mute. Hence I decided to take hold of my SLR camera and devised a little test to proof that motion blur DO exist and is more or less apparent depending on the display technology being used. Before I tackle the issue of motion resolution, it is important to differentiate between 2 major factors responsible for this blur: Slow Response and SAH(Sample and Hold) effect.
Slow Response is usually caused by pixel not being fast enough to change state for every frame. LCD/LCOS are especially vulnerable to this problem. You can notice it with fast camera pans, fast action sports, and it is especially obvious when group of pixels of close tonal range are moving around the screen. Motion blur will introduce softness to the image and can hide subtle tonal changes in people skins and textures.
In theory, it shouldn’t show with PWM (Pulse width modulation) display since they change pixel state(on/off) almost instantaneously(in micro seconds). For instance, DLP is totally immune to this type of blur (as we will see in the next images). Plasma might leave some phosphor trails and hence some models tend to exhibit this flaw to certain extent.
SAH (Sample and Hold) effect is due to how the eye-brain interprets the image perceived. Since light falling in the eye retina is persistent and the brain integrates light intensity over a short period of time, a certain amount of blanking time is required between frames for the brain to easily differentiate sequential images and interpret movements. Not doing so, the brain will integrate and join 2 subsequent frames and this will be perceived as fuzziness in the image. LCD/LCOS blanking time is almost nil since pixel state is always on for the duration of the whole frame. Single chip DLPs have some blanking time but definitely not as long as 3 Chip DLP due to its color wheel that turns several round per frame and display each color twice per round. 3 Chip DLP blanking time is directly proportional to pixel brightness intensity, and knowing the average pixel IRE hover in the 30s, add gamma to the equation and we’ll get on average very long blanking times with off state mirror time. CRTs have relatively long blanking times as well (about 14ms with 60fps material assuming 2ms phosphor decay time)
The Test:
My test is easy to reproduce by anyone who is feeding his PJ with an HTPC running Windows OS and is curious to assess his display and his motion sensitivity. There is a XP screen saver named “marquee” that scroll a text horizontally. I went to “marquee” settings and filled the text box with “ININI”. I then started playing with scrolling speed trying to determine the text legibility speed threshold above which I couldn’t read the letters anymore. I performed this test with LCD/Single Chip DLP/LCOS/CRT and took screen shots with my camera at different shutter speed. For reference, I decided to attach 2 screen shots for each display tech I tested. One taken with a 1/340s shutter speed that test pixel response ability to redraw the text at different location for every frame. I added another with 1/60s shutter speed that mimic what my eyes perceive (I tried about 20 different shutter speeds from 1/20s ->1/500s and found image produced by 1/60s best reproduce what MY eyes actually sees).
The Test:
. Now I have another program named (juddertest), you can google and the program, you get to choose the speed of the scroll(Nb of pixel per refresh rate) and number of Refresh Rate per frame. That should be enough to perform this comparision for 24fps material. I did the comparision andthe results somehow close to what you get with 60fps. ie: CRT>DLP>LCOS>LCD.
