The only reason I offered Windows Moviemaker is because it is free which is what most people are looking for.
What I personally use to do what you are wanting to do are the following programs:
Adobe After Effects
Adobe Premiere
Sony Vegas
Windows movie maker is way to primitive.
That's funny...
I think the same thing about Powerpoint.
Seriously, if you plan on making any video, Powerpoint is NOT the way to go. But I like a challenge so, if you are like myself then you may just want to do it so you can say that you did, which is cool.
m2ts is the proprietary format that Sony uses internally in the PS3...
Not sure if it will play other formats or not... (refer to the Custom Hi Definition thread by Volley) they have talked about this over in that thread and can offer more answers on m2ts than I ever could...
I know what you mean... Wish they could just create 1 standard and stick to it but alas, that will never be...
Originally Posted by
DarrinH
I would like to do something through Powerpoint which has many more options for animations, transitions, etc...
m2ts is this a container or a type of video file?
All of the different file types and containers confuse me.
