I have 5 HDMI sources in...PS3, xbox, dvr, apple tv and blu-ray player. All work good. I want to hook up my Wii...I have a component adapter.
I am a little confused on where to hook it in. And how to switch to it.
First of all...since I am using 5 hdmi is that all I can run in? I assume I could use one of the inputs and toggle between HDMI and component. I can switch the audio but its not clear from the manual how to swap the video. Ideally would like to switch from the remote..or the front panel..once its setup.
What are the steps?
What input should it go into, video and audio? What settings do I use in the configuration screen?
The receiver is awesome...and hdmi switching works great..but the manual gets dense with the above so was looking for some clear steps. Thanks!
Frank
What are the steps?
Frank
