AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Mounting question - 24" studs
post #1 of 22
I purchased a mount for my 42" Panasonic from monoprice, not even thinking that I wouldn't have 16" studs. Well, I have 24" studs and the mount has a width of ~20". I am at a loss of what to do, and am not quite sure how to mount it. I'd really like to avoid cutting open my drywall to attach 2x4's between the two studs.
The TV weighs 57lbs and I would guess the mount weighs ~20lbs. Is mounting one side to a stud, then using a strong anchor on the other side a bad idea?
Any help is greatly appreciated.
post #2 of 22
no, mounting to one stud is not a good idea. given that you have only a 60lb tv, you can get away with it (though not the best way) only if the wall bracket of the wall-mount will be pretty much centered on the stud. your best bet is to mount a support plate a 18"x26" 3/4" thick ply or particle board across the two studs and then mount the tV mount on it. if you need detailed instructions, send me a pm.
post #3 of 22
ygm. thanks.
post #4 of 22
Why don't you just go and buy a mount that will cover 24" studs, it will be a whole heck of a lot safer and easier.
post #5 of 22
I got a Panasonic 58" PZ800U which weighs 130lbs. I also have studs that are 24" apart and don't necessarily want to take the wall apart to add reinforcement between the studs. I considered the particle board/plywood intermediate plate. What special instructions do I need for that?
I got this mount which has a 19" backing plate: http://www.monoprice.com/products/pr...#specification
post #6 of 22
Originally Posted by daniel'son View Post
.. Peerless ST670.
How is that helpful? I need a mount that will extend my set out 20" from the wall. The only one other than the Monoprice mount that reaches out that far is a Sanus mount which costs around $500!
post #7 of 22
Plywood, yes. Particle boad, no.
First, attach the mount to the 3/4" plywood board, with flathead machine screws (wall side) through the plywood, and locknuts (mount side). Countersink the screw holes on the wall side so that the heads will be flush with the wall.
Next, use a couple of drywall screws or small nails to fixture the plywood/mount assembly to its final location on the wall. Then, after drilling 7/32" pilot holes through the board and into the studs, use 1/4" Simpson Strongdrive hexhead screws (3" long) through the plywood into the studs. Eight fasteners, spaced as far apart as possible, should do the trick.
post #8 of 22
How bout you just go and buy the Sanus VMPL3B it will extend wide enough to hit to studs at 24" and you'll be fine don't go through all that plywood this and bolt this junk just to use some cheapo mount.
post #9 of 22
Because I need a mount that will allow me to extend the TV out 2 feet away from the wall. The Sanus mount that does do that is $600. The Monoprice mount is $80. Huge difference in price.
Thanks for your extremely informative post.
post #10 of 22
I'm having the same issue. Didn't see that the monoprice mount was only 19" and didn't realize my studs were 24" apart. I'm considering adding a support plate, but I didn't think plywood would do the trick. If I attach ~ 28"x12" plywood to the studs, how much weight should it support? And how would I connect it? Lag screws for both the plywood/studs and mount/plywood? Primetime's way seems a bit complicated for me.
My tv is about 50 pounds and the mount is about 30. Obviously, I REALLY don't want it crashing down.
post #11 of 22
You could always buy a larger metal plate, drill it where your studs are, and have a muffler shop weld it to the mount.
Then, there's always UniStrut....
post #12 of 22
if you do it probably, nothing will crash and and it is not that difficult. You do need to know how to locate studs, drill holes, etc.
see pic below....my tv weighs 138lb, its extends over 50" from the wall and after 30 months, nothing has crashed.
send me a pm if you want detailed instructions.
post #13 of 22
Thanks a bunch to drgkja for excellent instructions he PM'd me on using 3/4" plywood as intermediate boards between my wall mount and the wall. I managed to install Monoprice mount 3725 to 24" studs with his well-detailed method.
I ended up using two 3/4" plywood boards measuring 40" wide x 20" tall. I hit 2 studs with 3 lag bolts in each stud (3/8" diameter, 4" long lag bolts). The actual mount's wall plate managed to hit one of the 2 studs, so 2 of the lag bolts are holding the wall plate on to the stud.
I painted the plywood black using Krylon spray paint, even though it isn't visible from the top of the TV unless one is standing about 2 feet in front of it.
Here is a pic of the plywood and wall mount assembly:
Close-up:
And finally, from the front of the TV (floating 26" from the wall):
post #14 of 22
you are very welcome.....enjoy your new tv
Close-up:
post #15 of 22
Hi all,
would anybody PM me the detailed instructions?
I am also in the same situation of daMaster, same item too!
Thank you
Alex
post #16 of 22
Here are the instructions. I take no credit for them as they came from user drgkja:
Originally Posted by drgkja View Post
here are the instructions. in addition, since you have a big tv on an articulating mount, which hangs several inches from the wall exerting extra load on the upper bolts as well as the intermediate wood, i strongly suggest the following--
1. must use 2 sheets of 3/4' thick plywood (or particle board) slapped (laminated) together.
2. the vertical dimension of the boards should be at least 24".
3. horizontal dimension: if i were doing this, i would use 50" wide pieces so that the intermediate board(s) will be mounted on 3 studs. i don't think the wood will be visible as your tv almost 60" wide
4. try to mount the mount-assembly as much near the center of the intermediate wood as possible. hope your layout (viewing position) will let let you do this.
general intrctions for using an intermediate board(s):
1. get intermediate boards as above.
2. before you attach the ply to the wall, attach the wall side of the wall-mount to the ply (s). use 6 5/16" flat-head, 2" to 2-1/2" long bolts/nuts. to do this, feed the bolts from back side of the wood towards you...so the nuts will sit against the surface of the metal wall-bracket of the mount; and you should countersink (taper) the back side of the hole in the wood so the bolts-heads are reasonably flat with the ply so this assembly (bracket and ply) should be fairly flat on the back and it can go flush against the wall.
3. now you attach the hole assembly to the wall using 6 (for 2 studs) or preferably 9 (for 3 studs) 5/16" or 3/8" dia, 4-1/2" long lag bolts. (remember to drill 7/32" 9/32" pilot holes)
You can also see the pictures of my install in this post: http://www.avsforum.com/avs-vb/showt...3#post15724643
post #17 of 22
Hi,
the instructions report 2 sheets of 3/4' thick plywood, but from the pictures you used only one I guess?
My TV is 46" and its dimensions are: 44 3/4 x 29 x 4 7/8 so I was thinking to 1 3/4' thick plywood panel with the following dimensions: W 31.5 x H 14
I would assume this to be enough given that my TV weights 71 lb
What do you think?
Thank you
Alex
post #18 of 22
Originally Posted by Metallo View Post
Hi,
What do you think?
Thank you
Alex
I'm using 2 sheets. Maybe it isn't clear in my pics because I painted them black.
And I used 3/4" sheets not 3/4' 3/4' would be very thick
post #19 of 22
When I bought the VT25 I discovered that where I had my center channel speaker was blocking the remote and the 3D sensor. I ended up making a small stand out of plywood and "bun feet" from Lowes to raise the TV above the center channel.
That plywood sure likes to suck up paint, right daMaster? Nice looking job and no worries that will ever fall down.
post #20 of 22
Hi,
just to be sure I have well understood, I am from Europe and am used to cm more than inches, I live in Canada where I was expecting to use cm, but I was wrong
Anyhow, you overlapped two plywood boards of 3/4" each, which means what I see in the picture is 1.5" thick ?
The size you have used is 40" x 20" which is basically the double of the wall plate size both in width and tall?
Sure your TV weights twice as mine, that's why I am wondering whether I should go for 1 layer instead of two.
Have I well understood the dimensions you cut your plywood?
Alex
post #21 of 22
daMaster,
would you please reply to my last question?
It is important to me.
Thank you
Alex
post #22 of 22
[quote=daMaster;19905684]Here are the instructions. I take no credit for them as they came from user drgkja:
I am in a similar situation with 24" studs, and a 16" mount.
Do you think I could use two pieces of 1/2" plywood in place of 2 3/4" pieces? Or alternatively use a 3rd piece of 1/2" plywood to get the same depth?
I am mounting a 30lb VideoSecu articulating mount (MW370B) that will be extended a decent amount for a corner mount, holding a 59lb 46" LCD (LN46C630).
I've had 3 1/2"Dx32"Wx12"H pieces of plywood cut, bought 6 new 5/16" lag screws + washers to mount to the studs, and 6 1/4" flathead countersink bolts + nuts/washers/lock washers to attach the mount to the plywood.
Any advice on using 2 or 3 pieces of 1/2" or if I should go back and get the 2 3/4" pieces?
