Originally Posted by Somewhatlost
one zoneplayer (or the AP point if you bought one) needs to be connected to your 'network', your PC (you really want to have your music stored on your PC? I actually have it stored on an external harddrive. Does that change anything?) needs to be connected to your 'network'...
your 'network' could be just about anything... how do you connect to the internet? dial up or broadband?
Broadband via wireless router
a simple network would be just your PC & one ZP (or AP) plugged into a cheap switch would this mean plugging into an open port on my router? What about plugging into my zone bridge? I apologize if this sounds elementary, but I don't know much about this stuff.... or even to just each other with a cross over cable...
one thing you may want to consider in the future... a NAS... D-link makes some good cheap ones, as do others... get a 2 drive NAS, through two equal size drives in there and do raid 1, (sounds complicated if you never done it, but its amazingly simple to actually do...)
then you wont need to turn on your PC just to listen to music...
Thanks for the response and the help. I just hope I'm not biting off more than I can chew with this.
I didn't go last week for a few reasons and now I should have. I'll try and go today and see if there are actually any since I'm not sure how accurate those online things are anyway.
