I am trying to move my components into a cabinets where there will not e line of sight for the IR remote. Looking at buying a new receiver that I can plug an IR "eye" into and then place the "eye" on top of the cabinets. Seems like every receiver I look at that has this feature is around $600+. The one exception seems to be the Denon AVR-1708, which lists "IR Serial Remote In/Out terminals" as a feature. Does this mean I can plug an IR "eye" into the receiver? If not, what exactly is this feature? Thanks.
. This thing, IMO, is more than enough for your needs. Use the learning command, not the preprogrammed.
