Hello,
1)Is it possible to install an inwall speaker, where the wall is not of plasterboard? It is a slolid wall (limestone), about 6inch thick.
I`m interested in the jamo inwall C 803 IW speakers (link : http://www.jamo.com/Default.aspx?ID=...roductID=18052)
The other option would be the jamo c80 Sur speaker, but that would be protutruding 7 inches from my side wall, and i hate it aestetichally!
(link http://www.jamo.com/Default.aspx?ID=...roductID=17855)
You'll have to chip out a cavity for the speaker or it won't even fit into the wall. And if the cavity is a few inches deep, there won't be enough air space for an infinite baffle design, as all open-back inwalls are. Bottom line: Bad idea. I would look at onwall or inceiling.
